What PSU for this setup? (help a n00b)
[m]idas06
Building my first rig, don't really know what wattage to get/ which one.
This is the setup so far.
AMD Athlon 64 X2 Dual-Core 4200+ 2.2GHz Socket 939
Asustek A8N-SLI nForce4 SLI
2048Mb Corsair Value Select PC3200 DDR400 Memory Kit
GeForce 7600 GT 256MB PCI-Express
Western Digital 250GB 7200 8M SATA WD2500JD Serial ATA HDD
Samsung TS-H552 Dual Layer 16X DVD Writer
TP-Link 108mbps SuperG Wireless PCI Adapter
Thermaltake Mambo Case
This is the list I can choose from
I want to find the best possible ratio of low cost: performance.
Thanks
Why do you have to pick one from that list? How much do you want to spend???
Enermax would probably good. That list has several on there. But most of that list appears to be crap.
Christ, that's a huge fucking list. They should have some way to order the results.
