What program do you use to overclock? (9800 pro)
Sunni_Phono
I'm looking for something new. I've been using ATI Tray tools for a while and I keep getting errors with it now. What do you recommend? Thank you.
Open the program. Go to Settings. Then Misc. tab. Then check "Load On Windows Startup via" and set that to Registry Key.
Good luck.
Last question. So even with the program not in the system tray it still has my card overclocked? Thanks
