What Power Supply Do I need ?
okocha
Hi
I just registered to the forum
I m having problems with my CPU since I upgraded my configuration. I dont know much about computers. I used to have an old computer and wanted to buy a new one but a salesperson advised me just to upgrade it as its cheaper. So I did, a year ago. Anyway last couple of months my computer started restarting and I found out that it heats to fast. I started searching for a problem and found out that my power supply isn't good enough anymore, since I didn't upgrade it..
I have :
3 gb of RAM
500 gb hard disk
Intel Dual 1.6 1.6 Ghz
512 mb ATI Radeon
My power supply is 400 Watt
What power supply do I need, and what is the best quality I can get for $150 or less
Can you give specifics of your components? 400W is way more than enough to run that stuff, even a shoddy one.
