Right now i have a Vg33 Motherboard. Its socket 478 with the chipset of 845GE.
Here are the rest of this motherboards specs
http://www.fic.com.tw/product/motherboard/1stmainboard_detail.aspx?model_id=119
Sence this things BIOS is locked and im an overclocker, i think im going to get another motherboard.
The one im thinking about is an AB60R Shuttle motherboard. Its socket 478 with a chipset of 865PE. Not only for overclocking capabilitys but for other reasons this board is better. Like It supports AGP 8x, my card supports 8x but is running in 4x because of the motherboard.
more details below.
http://global.shuttle.com/Product/MotherBoard/mbd_Spec.asp?M_id=50
Is this MotherBoard compataible? Is it a worth while upgrade?
If i re-install windows with this new motherboard, the BIOS won't be locked, correct?
Wheres the best place to buy this motherboard?
I won't be geting PCI-E so thats not one of my worries. If theres a better Motherboard thats compatible please tell me.
The guts of my computer are listed below. Thanks!
more details below.
