what mobo to get?
jimgeagea
i kinda had some bad experiences with DFI,
i bought ultra-d, it wasn't working !
i bought a second one, it was properly working, till i plugged in, a second sata hdd, my system used to take 1-2 seconds to finish the boot screen, now it takes more than 20 sec to login, so i had to remove the second SATA...
is it normal to have such issues?
is there any mobo, like a dfi in performance and speed and realibilty, but with no BUGS and problems???
or is there anything i should do to fix the problem i have?
