What microphone should I use for language learning software?
Mangudai
Specifically Rosetta Stone, I know about the more popular, moderately priced mics out there like the Yeti etc. What I'd like to know is how much should I spend to get a mic that's good enough to be used with voice recognition/language learning software?
Thank you.
You want one made in the country you are trying to learn the language from. /s
Pretty sure the mic in your laptop will work fine. It is usually more about the mic that fits your comfort zone.
Thanks a lot guys. As it turns out, my built in laptop mic has been working just fine like some of you said.
I'll give this a try, looks interesting.
It's AMAZING. It's a completely free product that has premium features.
