http://www.bit-tech.net/news/2005/06/03/msi_amd_btx/Morley said:Shit you not I saw an MSI board with a Geforce 6100/430 chipset that was mBTX.
still not out.
I'd toss that in a spare btx case in seconds if it were available.
No it doesn't. I've used a P4 840EE @ 4Ghz and I've used Athlon 64 X2's. What you're describing is nothing more than a placebo.NulloModo said:Those benchmarks aren't what I am talking about. Sure, the X2 4800 performs better on a single multithreaded app at the same time as a P4 840EE. However, in overall system responsiveness, quickness switching between things, and just how 'smooth' things feel (Granted, something very hard to benchmark) the EE has it all over the X2.
Well, it's easy to build a system that sounds like a jetliner...but trying building a dual core system that is cooled by only one fan, and that includes two hard drives and a Geforce 6 class card...NulloModo said:Personally, I don't give a damn about small and quiet, I will always have a full tower with fans going everywhere, loaded up with at least 4 internal HDs, 2 or 3 optical drives, and more expansion slots than I can shake a stick at.
pxc said:I haven't had any stability problems with any Intel CPUs (P4 NW & Prescott) or chipsets (850 and newer) for the last 4 years... or even before that.
I can not say the same about AMD chipsets (or even A64 CPUs) over the last 4 years.
Yeah, there are 6/7 slot BTX systems like the Dell XPS and other systems.NulloModo said:I thought BTX was for SFF systems? Or is it going to move over for full size computers too?
Morley said:Well, it's easy to build a system that sounds like a jetliner...but trying building a dual core system that is cooled by only one fan, and that includes two hard drives and a Geforce 6 class card...
It's just sublime to me...
Yeah, but I'm sure you don't want that noise at work.NulloModo said:True, but, I'm so used to the sound of my computer running in the corner of my bedroom that I can't go to sleep at night if it is turned off... kinda sad.. I always miss that fan whirr when sleeping somewhere else as well, it's just comforting white noise.
E4g1e said:For that matter, Intel's later platforms are actually less stable than they were back in the days of the PII/440BX chipset. C'mon, heat problems with the latest desktop Intel CPUs and chipsets which seem to introduce new bugs...
serbiaNem said:What keeps you going Intel?
MC FLMJIG said:Intel setups are very, very stable. AMD are good but not as stable as the Intels.
Morley said:Yeah, but I'm sure you don't want that noise at work.
Where did AMD announce that? That was the "enthusiast" speculation/theinq rumor. Look up a few posts, MSI showed an A64 BTX board.serbiaNem said:1. AMD announced that BTX would not be supported because it places the ram too far from the cpu socket.
serbiaNem said:2. !!!'! !!!!!!!! did a torture test of both an AMD and Intel system and found the Intel less stable. (this was bleeding edge hardware, however, but this is an enthusiast forum..)
serbiaNem said:The thread should have read: "What keeps you going to netburst?"
No, it was a Gigabyte/Epox NF4 and Asus 955X "pre-release test platforms" and 3 boards failed for various reasons. One reboot was due to using the wrong heatsink (see page 10 for complete log): http://www.tomshardware.com/cpu/20050603/stresstest-08.html. The Intel system was stable after replacing the faulty pre-release motherboards.E4g1e said:That was probably due to the fact that the Intel system was using a reference Intel motherboard, which did not allow for any voltage adjustments at all whatsoever, and was actually undervolting some of its components.
Right now, its cheaper to stay Intel. I planned out a huge upgrade, the works, but I just cant afford it. So for alittle under 450 I can get a system to keep me goin for another couple years (game wise)
Frobozz said:Sure I may not get 10,000 bungholio marks like my friends, but I have not had to tell any stories of my system locking up right as I was about to pop someone in BF2 either.
ScHpAnKy said:Only 10K bungholio marks? Geez, current Athlon 64's put out 28K!
and thus is how war began...serbiaNem said:Oh, I hear the p-M puts out 28,001 bungholio marks, don't feel bad..
gotkilled said:intel [email protected]..
++Ultra Wide said:price, i get in on the Dell deals and intel ends up being pretty cheap.
fenderltd said:The day amd gets their chipsets perfect is the day you will say Intel who?
MC FLMJIG said:What???
Mobo of your choice, 939 pin, anywhere between 75-125.
Opteron 146 - let's just say 175.
What else do you need???
Even if you want dual core Optern 165 = 325
E4g1e said:It depends on the motherboard. Many Socket 939 motherboards require PCI Express graphics cards. Thus, you have to factor the price of one into the cost.
Same thing with Intel. All of the currently-produced Intel motherboards require a PCI Express graphics card (unless that motherboard has onboard graphics capability). In addition, you will likely need to replace your existing DDR memory with DDR2 memory on newer Intel motherboards.
That's too rich for my blood. My whole system including WinXP and a decent video card needs to cost a max of $650. The A64 in my sig is at the max of my budget.MC FLMJIG said:What???
