Not available through retail in North America though, as far as I know.Channel Well DSG950V has the Gold rating...
http://www.80plus.org/manu/psu/psu_reports/SP722_CWT_DSG950V_ATX12V_950W_Report.pdf
80Plus statistics are a useful metric, since they require PSUs to maintain a standard of efficiency across most of their range. A PSU with a good 80Plus spec will have good efficiency all the time, except at very low loads (<20%).OhMyGod, I believe if you want to be efficient you must not simply look at 80 Plus statistics, but rather where your particular system will operate generally. How much power will YOUR system draw at idle and under load? If your system is like mine, going to a higher wattage PSU will only decrease its efficiency. It's not about money. It's about math.
Yes, it does depend on the temperature. 80Plus tests with an ambient temperature of between 18C and 28C as per their specs. A hotter PSU will have lower efficiency in general, although many higher-quality units don't fluctuate by more than a percent between normal ambient and hotbox testing.It also depends on the unit's ambient operating temps? Right? My system runs at 163w at idle, which is my typical usage, so I would be below 20% with the larger wattage units. So that's why he should know what his system will use. There are many sites you can Google to estimate a given system's wattage.
How are you measuring your load? If you're using a Kill-A-Watt, it could be inaccurate, since they can sometimes report over 100% efficiency with Active PFC PSUs.That's why I was saying he needs to know his specs first. And my system is a Q9650, Rampage formula, mushkin Ascent 1066 2x2, 300 gb velociraptor, x-fi titanium, GTX285, and said PSU above. And that 163w is with my 1600x1200 monitor.
Some program my geeksquad friend used.
Yes and a quick search would turn up this topic a million times over. Here is the recap:
1) APFC can fool Kill-A-Watts into giving you abnormally low readings (some times giving better than 100% efficiency)
2) Power supplies derate with temperature anywhere from 2w/c above a nominal rated at value to 10w/c.
3) Kill-A-Watt's and most power meters sample too slowly to catch transient loads (the Transient load from our tests is 117w and is COMPLETELY missed by Kill-A-Watts).
4) Power supplies last longer if you stay in the 40% to 60% range of their output.
5) power supplies are quieter if you stay in the 40% to 60% range of their output.
6) Power supplies are cooler if you stay in the 40% to 60% range of their output.
The power meters in UPS software are just as bad. You have to spend some change before you get anywhere near an accurate power meter when your PSU has APFC.
Admittedly I am a noob to computers. My knowledge of hardware and software in limited, and often temporary. If you notice I had question marks behind many of my statements. My natural environment is not behind a keyboard. I rely on what I read and what my computer friend tells me, but for the guy who says the 285 gtx uses 175w, get glasses. I said "at idle". I was just trying to help. Wow! Some of you guys need to get laid and unwind.![]()
Not necessarily. As long as ripple and voltage are in spec, all the components will be designed to handle whatever ripple or fluctuations there may be, and efficiency would actually be more important in terms of how much energy you waste (especially if you live in an area with high electricity rates).Tight Load Regulation & Low Ripple/Noise are FAR more important than a few points of extra efficiency.
I was trying to educate you, not criticize you. You're the one who's getting offended; maybe you need to get laid and unwindAdmittedly I am a noob to computers. My knowledge of hardware and software in limited, and often temporary. If you notice I had question marks behind many of my statements. My natural environment is not behind a keyboard. I rely on what I read and what my computer friend tells me, but for the guy who says the 285 gtx uses 175w, get glasses. I said "at idle". I was just trying to help. Wow! Some of you guys need to get laid and unwind.![]()
