what is the consensus for a C2D mobo?
jnmunsey
Just wondering what most people round here think is the best mobo for $150ish or less that supports the following:
C2D E6400
2GB RAM
SLI not required
great overclocker
very stable
no extra cooling needed for the north/southbridges
Did I miss anything?
This is for my buddy and he is currently set on the ASUS P5B-E
Any opinions are greatly appreciated.
P5B-E is best in the $150 range. The DS3 isn't bad, but it doesn't have the ICH8R southbridge. Might not need it though. Both are good boards.
Biostar P965 PT. Everybody overlooks it, i guess because of the brand.
I like the P5B Deluxe. The heatpipe northbridge cooler is worth the price of admission. Plus you get a bunch of useful shit.
I really like mine.
For $150 you have a wide variety. What I would do is write down each and every thing that you want for your system. Then go through say New Egg, compare each motherboard and try to find reviews/opinions on those motherboards.
Then go down your list of motherboards and just mark off each one that doesn't meet your requirements until you have one that meets what you need.
That is what I have been doing. The only thing I keep going back and forth on is SLI and what my exact price is for this new machine of mine.
You may even want to use Excel to help keep track of costs.
Put each component in a nice order and then plug in the numbers.
That's what I would do.
SoulMan901
[H]ocusPocus;1030636432 said:
So there you have it, there is no consensus :D
I think there's pretty much a consensus that you should either get the P5B-E or DS3. I bet those two choices would be what 85-90% of the people here would say.
