What is the Best Cost No Option Small Form Factor Case for a Silent and Small WC Gaming Powerhouse (3090, etc)
Boil
There is the 14.5L Mesh-Licious chassis, supposed to be on Newegg Jan / Feb 2021...
I will be moving my loaded C8I mobo ( 3900X CPU / 32GB 3600/16 RAM / two 1TB M.2 NVMe PCIe Gen4 SSDs ) & SF750 PSU over to one; adding in a Sapphire Nitro+ 6800 XT SE GPU & a 280 EK-AIO...!
EDIT TO ADD:
Well, I will NOT be moving into the aforementioned chassis, as it seems it does NOT have miniDTX motherboard support (as I was led to believe)...
Reactions: Epos7
Sparky
Sugo 14 houses my 10980XE, RTX 3090, 1Kw Seagate, and Kraken 240mm AIO. There is room for a 120mm AIO as well.
AVT
Both on water, using a 120mm + 240mm radiator setup. these are my temps when loaded playing warzone on 4k.
water temp is 41 (16 delta)
gpu temp is 59
Cpu temp is around 68
That's better than what Ali got, likely because of the extra 120mm radiator. How'd you fit all that in?
AP2
I’m running a 1k watt GUnique psu replacing the psu location with a 120mm radiator.
