Wow! A 4 GB 5970? How much is that going to cost?
Ha... haha... hahaha... yeah...Reports have it priced at a cool $1000.
Reports have it priced at a cool $1000. That's really expensive, but it's going to come factory overclocked at 900mhz or something like that along with having Eyefinity6 outputs and the 4GB of GDDR5.
Another month, another.....NOTHING.
They are doing you a favor, just pick up a single 5870 2gb card and call it a day. Save yourself $500 and about $6,000 in aggravation.
Where are they? Problems or something?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150500
Its finally here....a little to late?
will that extra memory be worth using on normal monitors 25" and under ?
to get your monies worth u better have 80" monitor right ?
Apparently resale value for any 5970 is <= 500 at this point, I'm sure they don't want to release this card as it still loses to 2 480s.
I find it kinda shitty that such an expensive card has only a 2 year warranty
Huh, I wonder if that's wrong, or if this is the beginning of the end of double-lifetime?
It's a custom card - something XFX is not used to doing. Either way, there will probably be no "performance equivilent" (like the HD4890-->HD5830), so XFX won't try to keep too many of these in stock, and won't even bother trying to replace them later on (sort of like GTX285 Classified from eVGA, or GTX275 Physx Co-Op).
