What fan for Abit IC7
spiroh
The fan on the northbridge died on me an I need to replace it. Any suggestions on a cheap replacement?
Thanks
I use the Swiftech one on my IC7-G, cools the NB pretty good, I also ran it fanless with just the bigger Swiftech heatsink and it did not get very hot
If you get a heatsink (without a fan), you'll not have to worry about this again.
Are there loops on your motherboard where the fan clips in, or holes where you can insert an expanding pin?
.B ekiM
