what exactly is HDCP compliant
D1G1T4L
i tried to search for HDCP on the web and the only thing i get is
High-Bandwidth Digital Content Protection. Created by Intel, HDCP is used with HDTV signals over DVI and HDMI connections and on D-Theater D-VHS recordings to prevent unauthorized duplication of copywritten material
so whats the point of exactly getting a HDCP compliant display?
Well I got a vx2025wm that isn't HDCP compliant and my HD cable box won't send a signal to it.
I have to buy a component to d-sub convertor...hopefully that will work.
So I guess it will only concern you if you plan on playing HD content on the monitor.
Certain HD sources (some cable boxes, some upconverting DVI players, in theory stand alone blu-ray and HD-DVD players as well as internal computer drives) are HDCP enabled. That means they have to 'handshake' with a device before they will send the full resolution signal, if the display does not understand the handshake (i.e. it is not HDCP compliant) the source device will either refuse to send a signal, or reduce the resolution considerably. If the display is HDCP compliant, then the source device will send the full resolution signal. It is basically a convoluted draconian copy protection scheme, but we are going to have to live with it, so if you are getting a new display, go for one that is HDCP compliant, it doesn't mean that it won't accept non-HDCP sources.
EDIT: and just to make things a bit more confusing, there are two types of inputs that support HDCP input - HDCP-DVI, and HDMI. Not all DVI ports support HDCP, all HDMI ports too, but just because a device outputs via HDMI does not necessarily mean it will be requiring a HDCP display for input.
DOUBLE EDIT:
Does blu-ray show up as green and give you a pop up bubble on mouse-over for everyone else? Did the [H] start some funky new advertising thing or did some bizarre spyware end up on my computer somehow...
HDCP is a copyright protection. If you want to watch HD-DVD or Blu-ray movies on your computer in full resolution after say... 2010, you will need a video card and monitor that is HDCP compliant. If you don't have either, a few things can happen when a disc with the ICT flag (none of the HD-DVD/Blu-ray are yet, but it's possible in the future) is played. It will either play at a lower resolution, it may play for a few seconds before getting an error message, or it just may not play at all.
I assume they could carry this over to more content as well. I know Vista will use HDCP, but I'm not exactly sure what that will mean.
edit: Looks like nullomodo beat me to the punch.
It means no HD movies with a blu-ray or HD-DVD drive unless you are running Vista. From what I understand on the computer side your OS, video card, and monitor all have to be HDCP compliant.
Wel I was actually wondering if it means you may need it for other things than just HD-DVD, Blu-Ray. Perhaps some Microsoft protected downloads in their HD format or other things like that beyond the scope of the optical formats.
Except that so far neither BD or HD-DVD is enabling the flag to downrezz over non-HDCP connections. In the Blu-ray camp it's probably because the tard-pack PS3 doesn't have HDMI, and in the HD-DVD camp, not to piss off people using component - and the Microsoft HD-DVD drive Xbox360 addon is also going to be using component - no HDMI on it.
It'll likely be a while before the companies start shoving this intrusive copy protection down our throats :) :(
it's for copyright protection, a merger(like) between microsoft, some hardware and most hollywood studios to prohibit pirated movies from playing on our PC.
I think the more likely answer is the consumer uproar about it, and that even though the vast majority of people with HDTVs out there have HDCP compliant ones, not all of them that have them know they do. There hasn't been a HDTV made since the technology really caught on that doesn't have DVI or HDMI, and except for the very very very earliest DVI models, and the el cheapo sets, all have been HDCP compliant.
I would imagine once the one or both of the new formats becomes common-place they'll enable the flag. They want to to everything in their power to promote the new formats so they can re-sell their entire catalogue. Once we're hooked, they'll enable the flag to protect their precious content. Around this time they'll start releasing the super-duper collectors editions with DD Tru-HD, DTS-HD(whatever it's called) and VC1 (on the bluray side).
I think Microsoft is forced to support the HDCP chain in Vista otherwise they are not allowed to play HD-movies by law.
Does for me as well, looks like they sure have. :(
It seems to me that Microsft has added its own form of HDCP in WMP11 to protect WMV-HD: the price to pay-- upgrade your OS to Vista. I was able to playback the WMV HD format in WMP10; but after insalling WMP11, have been unable to do so even though all other video format playback (including hd.264) has been as good or better than before. I suspect that the WMP11 build for the new Vista OS will solve that problem. Has anyone heard anything about this matter.
High-Bandwidth Digital Content Protection (HDCP) is a form of digital rights management (DRM) developed by the Intel Corporation to control digital audio and video content as it travels across Digital Visual Interface (DVI) or High Definition Multimedia Interface (HDMI) connections. The HDCP specification is proprietary and an implementation of HDCP requires a license.
HDCP is licensed by Digital Content Protection, LLC, a subsidiary of Intel. In addition to paying fees, licensees agree to limit the capabilities of their products. For example, High-definition digital video content must be restricted to DVD quality on non-HDCP compliant video outputs when requested by the source. DVD-Audio content is restricted to DAT quality on non-HDCP digital audio outputs (analog audio outputs have no quality limits). Licensees cannot allow their devices to make copies of content, and must design their products to "effectively frustrate attempts to defeat the content protection requirements."
