Ideally you want 1:1, gained performance.
1600Mhz Fsb Core 2 chip, run your ram at DDR2 800.
1333Mhz Fsb Core 2 chip, run your ram at DDR2 667.
1066Mhz Fsb Core 2 chip, run your ram at DDR2 533.
800Mhz Fsb Core 2 chip, run your ram at DDR2 400.
Sorry
Gigabyte P35 DS3L
E8400
4GB G SKill DDR2 1000 dual channel
Easy, run your ram at 667, problem solved. Or if you have a good hsf, you can OC your proc to 400x8 or 400x9, and run your ram at 800.
Ok. So right now since its at 5:6 that means its running at 800? If I put it at 667 that means it wont run as fast as it is right now right? Looking at it x:y wouldnt it be best if y was high as possible?
Ok now I think I know how to calculate.
When FSB is at 333 and ram is at 667 its at 1:1 BECAUSE 667 is DDR so its really 1333. The FSB has a multiplier of 4 so it equals 1333 and 1333/1333 is 1/1 or 1:1.
When the ram is at 800 its really at 1600 and the FSB is still at 1333 and 1333/1600=0.83 and 5/6 is equal to that. It all makes sense now.
So I really only need the DDR2-1000 RAM I bought if i want to hella-overclock my E8400 to 500fsb? Guess I'll just be tightening the timings on the RAM then instead of worrying about FSB.
RAM wise, yes all you need is DDR2 1000 RAM. However make sure that your mobo can handle a FSB of 500Mhz. Some mobos can't handle that at all while some can if the Northbridge is excellently cooled, like with a small 40mm fan or a HR-05 NB HS.
So what is the reasoning behing the 790i boards only being ddr3? Suppose I pair ddr3 1600 with a
Q9550, would there just be no gain?
