so anyways it happened that I found 1 tb underneath my sofa for some reason I guess I purchased one few months ago but took it out of the package box but forgot about it... it is internal
the thing is my case already ran out of 3.5'' slot
and I have 4 sata connector but only really 2 are usable because my giant 470gtx is blocking two of them and my case is a med case
I have 8 external drives being powered by powered usb hubs and I kind of ran out of power stripes running from the outlet
I have one bluray burner that does everything
and I have a dvd burner that is sitting there because I only have 2 sata to use
I have 1 tb drive in the 3.5'' slot
I have 2 5.25''
2 3.5''
I have few options
buy the 3.5 to 5.25'' kit so I can plug the 1tb I found at the 5.25 and take out the dvd burner and let it sit there and collect dust
and I have to buy a sata card to use since I have no more sata ports
that will probably run me about 35 dollars with shipping
or I can buy an external sata enclosure for about 20-25 dollars shipped
and find another power stripe to connect it t
what do you think I should do?
I have 2 5.25''
2 3.5''
I have few options
