What do you recomend?
Messiah33
Hey [H], I want to be able to use my PC and Xbox 360 on my speakers at the same time. At first I had the Logitech z2300's for about $150 but I also had the Prelude so that i can plug my xbox into it via optical input to play out my speakers. Now I just found a 2.1 system that has optical in Edifier S330D 2.1 Speaker Set 72W RMS High Gloss Black Piano Finish Digital & Analog Input
$120, now I dont really Have a need for that 200$ soundcard. So can anyone recomend a soundcard for gaming to replace that one or is the onboard of the Gigabyte GA-P35-DS3L good enough. Also I am running Vista 64-bit with 4gb RAM.
If you are using digital output for a stereo signal, there is no reason to not just use onboard, since the soundcard won't be doing much of anything anyway.
Lower noise threshold. Onboard audio, while much better than it used to be, still suffers from a lot of crossover and EM interference from other motherboard components. A seperate sound card can help.
If you don't care about acceleration like EAX, I reccomend the Chaintech AV-710. Only $25, excellent analog outs and has TOSLINK (Optical) as well.
Not for S/PDIF....
Use onboard.
Yah this is pretty much false.
So I should just use my onboard for my computer games then?
Depends on how you going to connect them all.
Onboard audio via SPDIF is okay for most of games or if you don't care about EAX. You'll get a great sound clarity, no noise from internal components, etc. There will be almost no difference between onboard sound card and Prelude.
I'm pretty sure that my mobo has Optical/Coaxial out, so I'll just use that. Thanks for the help.
