What do U think about this PC ??
axl2000
I'm about to buy new PC (old: A64 3000+, 1024DDR, X800XL), but it should be PC for work and entertaniment (50/50) not only games.
I'm thinkin' of:
Intel Pentium D 945 (2x3,4Ghz) BOX (i don't want cheapest core2duo e6300, and e6400 in my country is too expensive for me...)
GIGABYTE 8N SLI nForce 4
2GB (2x1GB) DDR2 667Mhz
160GB Maxtor DiamondMax Plus 8MB (i don't need more)
BFG GF 7900GT OC 256MB (475/1360Mhz)
FROTRON BlueStorm 500W
Is this PC can handle new games in 1280x1024 ??
And maybe i should think about X2 3800 or X2 4200 instead of Pentium D ??
Poland...:/
Budget, hmh...it'll be about 830$ (i can have PC from my first post for about 800$ including DVD-RW and Case)
the slowest Core 2 Duo once overclocked a little bit would totally out perform that P-D, currently my 1.83ghz Core 2 Duo in my laptop is very powerful and handles absolutely anything. I personally think you'll be happier with the Core 2. But either way I'm sure you'll be happy :)
Dump that pentium D, grab a Athlon X2 if you dont want C2D. A Get a X2 3800+ or 3600+ if they have it in your area, and overclock it.
Curent setup looks nice I would tke the pentium d over the amd options,the amd options may perform better however if you take the pentium-d you can upgrade later to a c2d when the price falls without buyin another mobo.
well that's my point of view heh, but does this mobo can use C2D ??
you could spend 850 on a great C2D system with a G965 mobo and ddr2 800 memory here in the us
what's the price of a 6400 versus that D in poland? i'm not sure i'd reccomend an x2. what mobo is running your 3000? will it accept dual core? perhaps a x2 4800 + a nice vid card and another gig of ram will get you to the next step.
