What do I do with this completed result?
pduan87
So I switched over from FAH 4.00 to 5.02 just ealier tonight. The problem was that 4.00 would just not send the WU and I was in a hurry so I deleted the directory, saved the WU_results, and upgraded to 5.02. Now the question is, how can I (if i still can) send this completed result? This is a 100+ pointer and I want my points!
You need the queue.dat file that went with the wuresults_xx.dat file. If you didn't save the queue.dat file your pretty much screwed unless you know how to create a new queue.dat file that knows about the finished WU.
Do you happen to know the Project, Run, Clone, Gen of the WU?
ChelseaOilman
For future reference, you do not need to delete the folder or anything like that when upgrading to a new client. All you need to do is copy the new client into the same directory and rerun the config with the new client. After that you will be set to go.
