runLoganrun
- Jul 4, 2005
currently i have 1x150 raptor, 1x320 wd, 2x640 aaks, 1x750 aaks, one of the 640's is a backup to the other. i'm at max capacity and wanted to add a couple more disks, but not sure of configuring it. now i have 3 internal, and 2 external, and am maxed out for onboard connectors (i have two optical drives), plus using a usb connector, unless i get a raid card or something, which is what i am wondering about.
there's a certain amount of stuff that i want backed up, but not everything, at least the way it's set up now, it's just too many disks, and am wondering about setting up a raid 5 array. the problem is that afaik that's not a really good backup situation, because you could get a virus, or some other problem and still lose everything. how do you avoid this problem, do you have to back up the whole array? in which case that would again be too many disks.
what's the best backup solution for having a raid 5 array, or do most ppl not use anything else?
do all the disks have to be identical, down to the model, or just the same size?
currently i have my os/apps drive separate from all storage, would i want to keep it that way for raid 5?
is midrange controller card, like promise fastrak4310 (only one i saw for vista), way better than using onboard raid solution? one of the main things for me is that it would allow me to still have 4xraid5 drives plus os drive, rather than 3 & os.
thanks for any help,
rlr
rlr
