i had a gigabyte p35-ds3r mobo,e6850 cpu,2 gig corsair cmx2x1024-6400c4pro mem.,
raptorx hdd. This was all running on the mobo cardboard box for 3 weeks with no problems.I finally dedcided to install in a case , got an ultra aluminus case and installed
all the above parts. Fired up and it is dead,the fans run,the hdd runs but no activity,the
memory activity leds light on one stick momentarily and go out. I checked the mobo
tray and made sure no stand offs were anywhere but at hte screw holes. I removed
the mobo and put it back on the box set it up started it with the same result as in the case.What did i do wrong? Any help would be appriciated as i will get another mobo and
try again after i figure what happened. This is not my first install,but it is my first install
with a serious mistake.
