What Cpu to Choose
mir
I just bought Gigabyte GA-MA78GM-US2H AMD780G MB
What will be Good Cpu for this MB
It would be for HTPC purpose
What is your budget?
EDIT: oops posted athlon 250 its AM3, the 45watt athlonx2 would be a solid choice.
AM3 CPUs are backwards-compatible with AM2+ motherboards, so the Athlon II X2 250 would work in the OP's board.
Are you from Canada? If so, that is information that you should have provided already, since there's a big difference between $100 CAD and $100 USD, and it also means that you would need to purchase from a Canadian retailer.
If you are Canadian, this is your best option: http://www.directcanada.com/products/?sku=10360BD9935&vpn=ADX250OCGQBOX&manufacture=AMD
Actually I am not from Canada ;) But I am in Canada :D hee eee
Any Rate, Thanks :)
Please tell what is the difference one you have posted and this 250 Regor 3.0GHz beside the price ?
how slow (Clock wise) would be this or fast (due to more core) 9350e Agena 2.0GHz I know this is Expensive !
or even this Black Phenom II X2 550 this would ba a local pick for me (can save money on shipping) {$10}
Side Note I am not into O.C. Thanks :eek:
Nothing. They're the same CPU.
The CPU I suggested has a higher clock speed and is faster clock-for-clock. Unless you use a lot of multithreaded applications, the dual-core will perform much better.
That CPU is a bit better. If it'll end up being cheaper or around the same price, then I would say go for it.
550 might be able to unlock cores depending on the board you're using. Not sure on that gigabyte board (probably not).
Phenom II X2 550 is a great CPU for the price. It's currently $99 on Newegg with free shipping.
Edit: Ah, $123 CAD through Newegg Canada.
