What Cable Do I Need? :/
I've got two 120mm case fans on my PC and only 1 fan header on my mobo (which is being used by the CPU fan)
I have a spare 4pin molex power cable and a spare 6pin pcie power cable. Is there any converter I can get to hook my fans up via either of these?
My HDDs are getting too hot for my liking (52 Celsius)
Cheers!
i would just put a 120mm in front of the hdd cage to help with the heat....spreading them out helps as well
anyways you just need a simple splitter or power box
heres another option
but theres plenty of designs out there, this ones just a simple solution if you don't have too many fans
