What block for Quad Core with my exisiting setup?
wrangler
Pump is a csp-mag, radiator is Black Ice Pro dual 120 mounted in the top of the case. All 1/2". Cooling CPU only.
I know the pump isn't a D5 but it fits in my case (Antec P160) and has worked well for me.
Thanks for looking.
With Quads, from my research, Swiftech Apogee GT / GTX and D-Tek Fuzion are the good picks for large IHS cooling. This is what I will get myself with my Quad (love when everyone is going in the quad bandwagon :D ).
Another block soon coming on to the American scene is the Aqua Computer Cuplex XT DI in a G 1/4 thread. This block is specifically designed for duo's and Quads. This link is for a G 1/8 thread.
Holy crapola, take a look at the pump first TN. A restrictive nightmare of a block on a CSP-Mag when you could get the free flowing Fuzion or Apogee...its a no brainer.
As was said earlier, with that pump, and quad cores, you really have two best choices. The Fuzion or the Apogee GT.
QFT............;)
Top Nurse [H]ardness Supreme
So is the APOGEE GT/GTX and Fuzion...............;)
The GT's primary difference with the Apogee™ is an optimized internal structure. The improvement in thermal performance scales from a minimum of 1°C and up to 3°C (at 100W) depending on the CPU's, with Intel's latest QX6700 quad core processors benefiting the most from the revised structure
http://www.swiftnets.com/products/APOGEEGT.asp
The all-new D-Tek FuZion™ CPU block will shatter enthusiasts' expectations about water block design, appearance, and high quality manufacturing. Unique to the FuZion™ is the 4 to 1 flow chamber design that provides outstanding flowrates while the unique baseplate design delivers thermal control more efficiently than any restriction or impingement based blocks currently on the market. The FuZion™ design is optimized for the current high wattage multiple core processors now on the market today.
http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=182&HS=1
Finger quivering over the GTX order button..................................
I got a soft place for Swiftech anyway. I bought an MCX-64V (the helicoil thingy) heatsink/fan for my first A64 when nobody was talking about them just by research and the damn thing was 12C better than the stock cooler. Course, they only sent out a hunk of aluminum with some fins and a fan for the 754 at first so probably anything was better but it instaled like a champ and looked as cool as it ran.
I've got the Apogee GT (Actually a three of them) and they are badass. One of them is doing well on my test bench and another is doing well on my Q6600. The last one is unused, but I will use it on another project soon enough.
Quoted from Aqua PC's site:
"The effective flowrate is nearly doubled by this concept, the area covered by the pin structure is significantly increased while the flow resistance is not noteworthy increased. The cuplex XT di is the perfect match to current dual and quad core processors but can also be used for all other processor types."
"As the predecessor cuplex XT, the cuplex XT di is a high end and high performance watercooler manufactured with nozzle-cooling technology. The bottom is made out of highly pure copper and has an optimized pin structure for a better heat transfer which is significantly wider spread than before. Accelerated via the first sets of nozzles integrated into the middle section made of matt chromed brass, the water is led onto the first area of pins of the copper bottom. The water then is redirected to the second set of nozzles and again accelerated towards the second area of pins of the copper bottom before being led to the outlet of the cooler.
"This cooler has an outstanding cooling capacity used on multi core processors as well as on traditional single core CPUs which beats the cooling capacity of all other CPU waterblocks in our product range. The cooler is planned for use with pumps of the type aquastream and 1046, more powerful pumps aren't needed and only effect a slight advancement of the cooling capacity."
Indeed.
I think it's a close enough call with these 2 to leave it to aesthetics.
Any thoughts or concerns over nozzle arrangement between these 2. Which is the more "free flowing"?
Indeed.
I believe the fuzion has less of a pressure drop.
Can anybody confirm that Fuzion is less restrictive. I have looked at the graphs but one company is in mH2c? and the other is in PSI and well...............beyond me. I just know how to hook this stuff up.
I might end up with Fuzion by default.
Swiftech site says it might be 2 weeks before the block ships and a lot of people are out of stock and the online stores that have them are wanting 79.95 .......................bastards. j/k I guess thats why they still have them.
Jab-tech.com has both the GTX and Fuzion at the best price on the net :)
Thanks for that info migueld. They should send you a referral fee.
I guess we can put this thread out of it's misery. Just ordered the Apogee GTX from Jab-Tech.
I'm sure I'll be posting the OC results and temps once everything gets here.
Thanks to all for the help!!
Good choice.
GTX for quads, for dedicated cpu loops, and for strong pumps
Fuzion for C2D's, for restrictive loops, weak pumps.
Bow your GTX and no other block can remotely compete with the temps other than a bowed Fuzion WITH 4.5mm nozzles.
So basically they are saying that the flow resistance is higher than the Cuplex XT, something that is already one of the most restrictive blocks you can buy. The CSP-Mag isn't even as good as the aquastream...soo....
Hehehehe.......I slapped an Apogee GTX (very cool looking I must say) at the end of my Nautilus 500.
Besides looking very nice, the temps at idle and at load are about 2-5 degrees lower right now than with the stock cooler that came with the set.
I got mine from Performance.:D
I've got the Apogee GT on my Nautilus. It works a little better than the stock block, but the difference isn't earth shattering. The stock block actually isn't that bad, it's just got crappy mounting hardware.
I agree with the mounting hardware. It was good because I didnt have to remove the MB, but it just doesnt seem really stable to me......plus the foam thing......I dont know.....
As for temp differences, I think the mileage may vary there. I dont have a real killer OC, so maybe thats why.
Right now I have an e6700, I'm really on the fence about the Q6600, but damn, the price drop is so tempting.......I have a wish list loaded at newegg, if they drop the hammer Sunday I'm going to have to bite.
I like the Nautilus alot.:D
I've read blurbs and seen references to this "bowing". Can someone explain more about this?
Intel screwed up their production of processors and the Integrated Heat Sink (IHS) was bent. Thus people want to bend their blocks to fit. I ain't buying a water block that can only be used on one manufacturer's set of CPU's. Others gleefully bend their blocks to match. Until Intel fixes the problem I won't be buying any of their products.
basically you make the bottom of the water block convex, so when mounted it will put more pressure in the center ensuring better thermo contact and reduce temp
I guess what I mean is that there is something about using an oversized O-Ring but I've read that it is hard to make that thing fit but I don't see how you can actually effect the shape of a solid copper water block with an O-Ring. I thought it had something to do with bowing something internally or the top or........................
Swiftech includes an 3mm o-ring (instead of the stock 2.3mm) with the Apogee GT. When you put it in place, there is definitely a slight curve to the copper plate. I haven't gotten it mounted yet (I'm waiting for the Q6600 price drop), but I imagine the pressure of having a cpu under it will cause it to conform to the surface.
It takes a little work to install, but wasn't too difficult. I just used some plastic clamps to hold it down as I worked it around the channel in the top.
Ah. Plastic clamps is a good idea. OK. I'm definately gonna give that a shot. I'm guessing since they provide the O-Ring your not voiding the warranty? I've only used DD blocks in the past and they always have that little sticker so if you open it up your screwed.
I don't think the copper block bends, but the base does, it causes more pressure to be applied to the center of the block.
Just because you *can* bow the block doesn't mean you have to. I don't know of any block that is processor specific (mounting hardware aside).
To the OP : If you do decide to bow your block it is a one way process. Once you warp the copper you can't undo what you have done. So make very sure you want to do it.
Let me rephrase that, I won't buy an Intel damaged product till they fix the problem. ;)
To TN, there is optional mounting hardware for other processors.
After you bow the block the only way to fix it is to lap the hell out of it.
5C on average from bowing. It's quite a large gain. See testing results done by Nihksub1 of the leading cpu waterblocks on the market today: http://www.xtremesystems.org/forums/showthread.php?t=151781
It includes bowed and nonbowed results.
It's still a shitty fix to have to use any manufacturer's product.
