What are your FEAR settings?
belmicah
I would like to know what settings you guys run. I just have a 5900 se, and I can't seem to twreak it just right to my liking. I mean, the game looks ok, but I had to turn most settings to minimum. How can I get visual ly pleasing settings with my sig. I have the newest video drivers, but I might try optimized ones. What is the best?
My system is a little different than yours but here goes.
For singleplayer: 1920x1200 no AA, 4x AF, no soft shadows, everything else maximum.
Multiplayer: 1280x800 4x AA, 4x AF, no soft shadows, everything else max.
With my old X800 XL, it was 1024x768 with everything maximum (no SS) and 2xAA with 4x AF. My frame rate was topping out at about 40.
WIth my 7800 GTX 512, its 1280x960, all settings max (no SS), and 4xAA with 8xAF. My framerate averages about 50-60.
Try running the game at 1024x768 with the settings on medium, and have minimal AA settings. It is a demanding game though.....
That card is going to be very slow for playing that game. FEAR is a pretty intense game on video cards, only with the latest high-end video cards can you run it with all maximum settings at a high resolution with AA and AF.
chinesepiratefood said:
2560*1600 8xS AA 8xAF on a fx 5200 very playable
Right.
Anyway, here are mine [limited to 12x10 native on LCD]
1280x1024 8xAA 16xAF no soft shadows
Bona Fide said:
I had a 7800GT on the same monitor. Here were mine:
1280x1024 2xAA 4xAF no soft shadows
were u using the same comp thats in ur sig minus the video card and monitor?
alkoholik said:
anybody with 7800 GT....what are ur settings?
I'm running at 1600*1200 2xAA 4xAF, no soft shadows and everything else at maximum. There are some choppy spots but overall gives a very good playing experience.
i got the same core speeds as you
468 MHz / 1096 MHz
but I havent even messed around with OC-ing it yet. From what I remember when I did the auto-detect in FEAR it gave me shitty settings....just wondering if u had that experience as well.
yea auto detect will give you a low/med setting. have to do it manually.
i have everything set to the max except for AA, which i set to 2x. if i have it on 4x some parts will lag just a tad. i dont really see the difference with 4x and 2x at 1600 * 1200
Just tested my settings again and i can play it at 1280x1024 with 4aa/16af and everything on max with my x850xt pe
1600x1200 No soft shadows, 4aa 16af. Everything else maxed. I get from 70-180 FPS.
One of my friends is running a p4 2.0A @ 2.7, 512 pc2100, and a 5950U (modded 5900xt) and he runs it at 800 x 600 or 1024 x 768 with medium details. The big thing is to make sure you run with dx8.1 shaders only, since the nv3x cards run dx8.1 shaders MUCH faster than dx9.0 shaders
My settings are: 1024x768 with a mix of max / med settings (ss off). I would say 75% max, 25% med. My framerate stays a solid 45-50 90% of the time.
Until I get my second gig of ram, texture detail must stay a tad lower or the choppiness cometh. :p
I have an Athlon64 3000+ s754 @ 2.4 and an XFX 6800GT.
On my main Rig (see below) I am running at 1280x1024 with 2xAA and 16xAF everything Max. I get a little lag in big firefights though.
On my shuttle Righ with its 6800NU I run at 1024x768 everything medium and 8xAF.
i have a 6600gt and an athlon 4000+ and i was wandering what settings i'll be able to use at 1360x768???
Ya, when I tried to play FEAR demo on my old fx5900se is when I upgraded. fx5900se has a hard time running the game at 800x600 medium setting. Looked like crap at 800x600 with no AA. looked like Half Life 1 at those settigns :(
With my overclocked x800xt it runs 1280x1024 res, high detail, no soft shadows, 2xAA, 4xAF
I run 1280x1024 with my system and with everything maxed out and no AA/AF at all. My minimum is around 20-22FPS and my average is around 40 or so with the latest 5.13 cats. I'm wondering how much my framerate would improve though with a new A64 3700+ o/c'd a bit. Would it really improve much for FEAR or is it more GPU dependant?
My rig will run it with everything turned up except soft shawdows gets a little choppy in big fights, but my old computer made it a slide show so i dont notice
well somthing in my comp is smokin crack or somthing cause when i turn OFF SS i lose 1-3 FPS in min/max/averg with everything maxxed(1280x960+4AA+16AF) ran bench a few times and it stays about the same
1600x1200, max details/physics, no soft shadows, no AA
1024X768, 4xFSAA, and MAX on everything available including audio (except soft shadows which looks like crap). This game humbles even a x1800xt at high res.
1280x1024, 4xAA 16xAF with setup in sig, average about 40 FPS
Oddly enough, in the demo I used to play it with 4xAA WITH soft shadows... but of course can't do that in the full version... looked pretty nice too.
For the guys running FX cards, try turning on DX8 shaders. That should offer a nice boost, allthough you'll pay for it in visual quailty :(
Single player - 1600x1200 no soft shadows every on or set to max.
Multi Player - 1600x1200 no soft shadows no shadows no shadow detail physics on minimum one of the physics settings I think particle bouncing is set to minimum for the nades and whatnot and I have corpses set to fade soon rather than longer (i play alot of dm and tdm :). I get 150+ fps maybe its 200 I dunno haven't played in a couple days :(..
lol...what is playable for you? :p
Mildly stupid question.. how will i know if soft shadows is on or not?
I've looked at the game with it on and off, and i don't see much of a difference.
Maybe i'm not looking at the right things? But my outline still seems solid, no fading or anything.
rig in sig.
Go ahead, push it to the max. You've got the same basic hardware as I do and I play it @ 1600x1200 4aa/4af max everything except no soft shadows and it runs great, and looks SOOO good!
There's a setting in the game called soft shadows. It's off by default I believe. If you're getting a playable game, there off cause it kills performance.
I've specifically turned it ON.
Also, i forgot, i'm on at 1280x1024 with all the candy.
1600x1200 looks better, but i can't have all the candy on, so it's a toss up.
I have played it that way but I lose some advantage in MP and I can always turn my gamma up some :). I mainly turn it down in some areas af and aa are cranked BTW I drop the nade smoke effects from cans and nades etc etc and sometimes turning down the world detail allows you to see mines easier since there isn't much to hide them.
I play to win but it's still gorgeous and yes it looks better with physics (nade smoke etc) and some of the other immersion items that hinder vision :).
