What am I doing wrong with this rebuild?
regerror
Hello everyone, I am new to this forum and this is my first post. Please help me if you can.
I have a computer that was starting to have problems so I though I would swap out some old parts for some minor upgrades. This is my first attempt at really messing with hardware so I was a little worried. Now the whole project is failing badly.
My computer is a Presario SR1538X. It came with an Asus K8S-LA Motherboard and an AMD 64 3300+ processor. The USB ports all started to fail so I ordered an Asus K8V-VM motherboard and a Rosewill RD 500-2DB power supply.
In the mean time I called HP tech support and after several long sessions they had me run PC Doctor, a hardware testing program. I ran it like 6 times and kept getting extended memory errors. So I ordered 2 stix of Kingston KVR400X64C3A/1G.
I put the new board and psu in with the old memory and processor but it wouldn't post. So I put all the old stuff back in and it wouldn't post either. The memory came so I tried the new and old boards with it and both still wouldn't post. Finally I got a new processor. The exact same one that came with the computer when I got it. I tried it in both boards and it still won't post. So far I can't get a post with any combination of components.
When I turn on the power with any combination of components the case fan and cpu fan start at high speed and stay that way till I turn the power back off. Any hard drive that is connected spins up and the monitor goes to sleep. Thats it. Its like it gets to or starts a post and gets hung up on some faulty and important component.
The old board has a small speaker on it and when I try to boot up it gives a never ending stream of single beeps which supposedly means that there is a memory error. At least that is what it is supposed to mean with award bios.
I am thinking that because I am putting this together on a steel work bench, I might have shorted some parts out, or my psu is screwed up and I have fried all my components. However I have tried my DVD burner in the computer that I am using right now and it still works so I don't know about that theory.
It stinks, I was so excited about my first build and now it has all headed south. Anyway sorry for the long post but I wanted to cover everything.
Well if you turn the motherboard on over that steel workbenck, then kiss it good bye, if not, make sure the ram is fully inserted into memory slot (kingston dimms are a bit tick) and make sure you plug the auxiliar 4pin cable connector (its a 2 yellow+2 black).
Hope it helps
oldmx
It could be possible that your case is shorting out the new mobo. . So reassemble the PC with the new parts with the new motherboard on the motherboard box, not a steel workbench or the case. Then try to boot it using a screwdriver to short out the power pins.
Also do you have another PC that you can test out your new and old parts on?
