That depends on the watercooling solution you buy. Do your research. Do not assume that all setups are about the same (or even close) in terms of noise.Interesting, how would the noise level compare with your suggestions but a water solution for the CPU and GPU. (Upgrading my case, fans, HD, and perhaps my PSU fan)
The 320KS is not quiet. It produces 70-80% more noise than the drives I mentioned above.My Raptor 150 is as quite as my 320KS in my Antec Super Lanboy. The only time it is louder is when I am moving a lot of non-congruent data to another drive.
I don't know how many of you where around for the loud a$$ hard drives from the 80s (man do I miss how they sounded!) but my raptor 150, though louder than my WD5000KS, is not loud enough to be distracting.
Perceived volume doubling ("twice the noise") is usually described as a 10dB increase.But to say it's twice as loud as an old 40GB deathstar I have in there isn't saying much - twice as loud is only a 3dB increase. I don't have a dB meter on me, but I would call my system 'whisper' quiet, with the drive noise not significant enough to matter. If I crank all the fans up, you can't hear any of the drives.
