Weird Stalker shadow bug
jbz7890
Whenever I play Stalker, I get these really annoying shadows at the edge of my screen (as seen on the bottom right corner in my screenshots). I have absolutely no idea what causes this, and they go away as soon as I rotate my mouse.
Does anyone know how to solve this problem? I have an ATI 4850 with Catalyst 9.6, if that's of any relevance.
After rotating my mouse slightly, they go away:
Try this:
1) Go to the directory containing your savegame folder and screenshots.
2)There, you will see a file named "user.ltx".
3) open this in notepad NOT wordpad.
4) scroll until you see a line that says "r2_sun_near_border 0.75".
5) Change the "0.75" to a "1"
Try this:
Thank you. I'll try that right now.
Ok that fixed it. Thanks :D
Out of curiosity, what does that command do? :confused:
This shadow bug occurs sometimes when using a widescreen resolution. I am somewhat positive that this extends the shadows displayed.
