Weird shut down/start up issue
Hey guys,
I have the box listed in my sig. Every once in a while, after I shutdown, it starts back up (after between five and ten minutes). I have an external hard drive that connects by firewire and it seems to happen after I've used that, though I'm not completely sure as it seems to happen randomly.
Do you guys have any idea what it might be? I haven't moved the box at all, so I doubt that it's a short or something.
Have you checked your BIOS for auto start settings. Make sure that nothing is set to turn your system on like Wake On Lan, IRQ activity or the keyboard.
Thanks for the reply.
All of those features are disabled in the BIOS, so I imagine it might be something else.
I would guess that there is either a short somewhere (maybe in the ATX case switch...do you use front ports for firewire connecting?), or there is some bios option you might have missed.
Hey I have the exact same issue on a computer I built for a friend. I thought it was an error that occured during shutdown causing the comp to start back up but I disabled that setting under advanced options (automatic reboot on system failure) and it still starts up. sometimes this happens even after a full 2 minutes after a complete shutdown. Its crazy! I'm thinking it's the powersupply. What ps are you using? I've tried reseating the power on pins on the MB but that didn't solve the issue either. Let me know what PS you're using and if you've solved the issue please share.
Just saw your sig so we don't have the same PS but I believe we're using the same motherboard. Maybe it's the MB that's causing this. Funny thing is the computer was running fine for 2 weeks while I loaded it up but as soon as I handed it over to my buddy the reboots started happening. No new software was added just his keyboard and monitor.
It's totally weird. I wonder if I need to update the BIOS? I dunno. Everything worked fine for months, and then only over the past month or so have I had this problem. Like last night for instance, I shutdown and then got in bed. Probably about five minutes later I heard the HSF coming on again. I just hit the Power button on the front of the box, but it's annoying that it does this. I often hang around for a few minutes if I shutdown and am leaving the house, just to make sure it won't come back on again.
Has anyone else had this problem? There doesn't appear to be anything that would be causing a short anywhere. Any other ideas maybe?
I don't believe it's a bios issue as I updated the bios when I did the clean install. One thing I did try is, I shut the comp down, when the comp was off but still plugged in I pulled the 2 power pins that go to the motherboard and the computer did not come back on. So I'm guessing something within the switch caused the power to turn back on. I'm using a kingwin case but honestly the power switch seems fine.
