DFI X38 8400 2 G memory
ATI x1800 video card
Windows XP PRO
just started this.
boot and the bios says verifying DMI POOL DATA
YES
now it just sits at this for about 10 seconds and doesn't respond then boots into windows
last try from cold boot
same no reply on DMI bios screen
10-15 seconds at windows welcome screen then goes to desktop which is blank.
mouse works but nothing else
now sure exactly what the pool data is but since it is not posting a YES and just goes to windows...Hardware problem ?
I know its supposed to be the boot record but can a hardware problem cause this?
It boots fine going into safe mode. Then a reboot and it will boot into windows. Next boot and same problems.
Windows XP PRO
just started this.
YES
