Master Honshu
- Nov 1, 2004
I have the MX 700 duo from Logitech. Just today a strange issue began where I could not type after a certain amount of time, however, the media buttons never stop working. After a reboot everything works fine, but after a certain amount of time(that I have not been able to determine), the keys will stop working again. I changed the batteries in the keyboard but it has not helped. I also tried plugging in a standard PS2 keyboard and the keys did not work on that one either, until a reboot, then both keyboards worked again.
I updated all of my adware/spy/virus programs and ran them all with no results. One final thing I have done is to disable Window Blinds which I have been using for about 4 months now without issues. If the culprit turns out not to be Window Blinds, then I'm not sure where to go from there. Is there something within Windows XP that can disable keyboard input? One thing I noticed is that when this happens I have not touched the keyboard in a while. Could it be some sort of time-out issue? I can't imagine how something like that could just happen. Nothing major has changed on my system in some time now.
Thanks for any help.
