weird install problem
yetshi
i decided to setup my second system to use as a dedicated file server and stripped down my newer PC for parts.
replaced the mobo and hard drive in the new system, went for a ECS P4M800PRO-M478 and a seagate ST3500630AS 500gig sata
created the driver floppy used F6 to install the driver
XP absolutely refused to install on the drive, couldnt ever format it, kept coming up with Unknown disk.
manual called for VIA VT8237 driver disk which is what i downloaded.
removed the sata and installed on a IDE.
setup completes, system restarts.
and setup starts all over again.
ive dban wiped the drive, ive ran fixmbr, ive ran fixboot.
same problem over and over again.
ive changed back to the old mobo.
still wont finish the install, just endlessly repeats.
current specs:
FIC vg33 mainboard
2x 512 kingston PC2700
WD 120gb hdd
evga 7600GS vid
onboard audio, lan etc...
any help would be appreciated .
you need to set the bios settings for the SATA to IDE and COMPATIBLE mode, then run the OS insall and at the F6 prompt install the driver for AHCI/RAID. After windows finishes installing and reboots, catch it and in the bios set the SATA settings to "AHCI" and "Enhanced" and when windows starts it will detect new devices and then install the "normal" SATA/AHCI windows driver and you are good to go.
Differnet MB makers call the above settings different thing, instead of "Enhanced" it might say "Native" etc etc. with a little thought you can figure it out or post back with the options for your SATA bios settings.
Basically you need to let Windows treat your SATA as an IDE drive during the install so you can get the advanced SATA drivers in, then tell it to look at the disk as a SATA disk.
