Weird G15 Problems?
spydermonkey
Well, I bought a G15 recently at Best Buy because it was on sale for $60, and I liked the look of it, and had heard good things about it. After I set it up initially, until tonight, I've had problems with my computer, drivers installed or not. The system would freeze for no reason, clicking on icons and the start menu wouldn't do anything, and before that, blue screens, but only with the G15 drivers installed. I finally tried a different keyboard, my old Saitek Eclipse II, and the problems haven't reared their ugly head yet. I tried installing windows xp several times, and my copy of Vista had the same problems, all with the drivers installed or not. Is it possible the keyboard caused all these problems? Is it possible I got a bad keyboard?
If you're running vista I know I've had some problems with the media extension crashing now and then.
I thought it was just Vista at first, but then I re-formatted a few times, and the same freezing happened in Windows XP.
Bit of an update, it's happening again, but at least now I know what's doing it. It seems every time I use any of the media keys on either my saitek or my logitech, the computer freezes up, but shows things working in the background. Media player keeps working, ctrl alt del works, and the windows key works, but I can't do anything with them. My clicks don't work anymore. Anyone ever have any problems like this before?
I hate to do this without completely knowing what the problem is, but I just don't know what to do anymore. I'm going to RMA my motherboard and see what that does. I'm convinced it's not software related, because it's persisted through about 5 formats and reinstalls of both vista and XP. I'm at wits end here, and if the motherboard doesn't fix it, I'm going to try and buy a new CPU.
- What are the specs of your system?
- Let me get this straight, the only time problems occur is when you use the media keys on your keyboard correct?
- Have you run any sort of diagnostic program on your computer? Like Memtest+ for your RAM and Drive Fitness Test for your hard drive?
Well, I thought it was only when I used my media keys, but I proved myself wrong, and it happens randomly while I'm using it.
I've run Memtest 86 - 15 passes, no fails.
Prime 95 - tests fine
Western Digital Data Lifeguard Diagnostics and Seatools tested all of my hard drives fine.
I've gotten IRQ_NOT_LESS_OR_EQUAL, MEMORY_MANAGEMENT, and PAGE_FILE_IN_NON_PAGE_AREA blue screens. None recently, though.
System specs are as follows:
Biostar TForce 939
512 x2 Crucial Ballistix DDR400
Sapphire x1900gt
Western Digital 160GB PATA 7200RPM
Western Digital 400GB SATA II(also tried forcing 150MBps)
Seagate 160GB SATA II Drive
XCLIO 450Watt PSU
And I think that's all that's relevant.
EDIT: Just to clarify, using the media keys is a sure fire way of getting it to freeze, but it happens randomly other times as well.
Well, I sent in my motherboard today, along with a hard drive that was clicking (not installed while freezing), so I'll let you all know how it works out. Thanks to everyone who helped, as well as everyone who looked.
