German Muscle
- Aug 2, 2005
Ive ran into an issue on this new build. Here are the specs before the story.
Gigabyte X299 Aorus Gaming 7 Pro Bios version F3j
Intel Core i7 9800x
GSkill Tridentz RGB 3200MHz 32GB
dual Intel 760p 512GB NVMe SSDs
I stood this up on the box and installed windows before doing the build in the case. Bought the m.2 drives with the intent to raid0 boot them but after researching it not working i found out only 1 m.2 goes to CPU and the other two m.2 slots on the board go to the PCH and it will not raid over multiple chipsets. Ok no big deal. I knew this could happen and im cool with it. Ill use one as a boot drive and the other for games and life goes on. So i went ahead and installed windows. During windows setup it saw one drive with capacity of 512GB. So i create a partition and format and go on with it. I figure once i get windows setup with all drivers it will see the other one and we can go from there.
Built the system in the case and boot it up and start updating windows and installing drivers. At the end of this the other drive is nowhere to be found. So i figured id pull one out and reinstall(if needed). Since the drive in the CPU slots heatsink is warm i figure thats the one that its using. However if i take any of the drives out it wont boot windows. I tried switching the single drive to different slots then put the one i took out in and try it and then switching slots with same results. I tried installing windows with just one installed in the CPU m.2 slot and it doesnt detect a drive at all. So i go load the F6 drivers on the disk screen of windows installation. It gets the driver but still shows no drive. I put both drives back in and in the same slots they were and windows boots fine. My C drive is only 512GB and i ran crystaldiskmark and its def not raid0. I also have a raid controller in device manager i cannot find a driver for.
I would really like to sort this out before i go much further with the system and installing software and setting it up in case i need to wipe and reinstall. Any ideas?
Intel Core i7 9800x
