DeathPrincess
- May 15, 2010
Just a quick check to see if this is normal or just me and if there are any fixes availible, anything i've just missed.
Ingame everything is fine, framerates are what you would expect them to be, as are tempretures. System is as stated below, with only a single 470 (the other cards are being used elsewhere right now).
But in the menus fans/tempretures jump into slaughter mode (about 85% fan usage and 85c tempretures even though there is absolutely nothing going on ontscreen). While playing the actual game everything is fine, framerates/fanspeed/tempretures go down to normal, even running the benchmark. But it makes using the army painter/menu/movie sections rather annoying as framerates rise to around 900 higher fps and the fan motors/tempretures raise abruptly too in the menus and at the end of each mission...
Tried turning settings down to the lowest possible settings makes no difference. On highest stettings it does the exact same thing too. Cannot see any vsnyc option.
Neither of the earlier DoW/DoW2 games do this...
Then part 2:
In the steam summer sale free DLC I unlocked the free helmet DLC for this game, but it doesn't appear to be in the game for the relevent race.
The DLC veiwer from steam is less than useful:
So I have absoltely no idea if I have this or dont have this... Neither side is resizable, nor is the box. Is there any other way of veiwing the availible content? as this thing is useless.
tl;dr option:
Framerates peak during menus/ingame movies to over 900.
Ingame framrates are fine.
DLC didn't unlock, steam DLC viewer is unuseful.
Then part 2:
tl;dr option:
