Negotiator
- Jun 11, 2004
So I was doing my daily price watch search, and I came across a site known as pcboost.com, which seems semi-well-known according to the feedback. Anyway, they had Athlon 64 3000+'s for a hair over $200, so I click in and afte selecting the Athlon 64 section, I was welcomed with this warning:
"Important Warning: Be Aware - AMD Athlon CPUs do not have the same type of automatic thermal protection / shutoff design as many previous CPUs and a single overheating incident can permanently damage your CPU. Proper cooling is critical. Even with a fan heatsink in place heavy CPU use can cause the CPU temperature to increase. Proper system & CPU cooling is critical."
The Intel side of the site had nothing of the sort listed. Apparently, you can slap a P4 in the middle of the sun and that SOB will keep on ticking. So, for all you about to buy an AMD chip, remember that "heavy CPU use can cause the CPU temperature to increase."
Linkage
Linkage
