Weal link? CPU or Vid Card??
Jinxx2
Ok I know neither one of these are cutting edge, but I'm trying to figure out which is the weaker link..
System basics :
x2 3800+
2gb OCZ 6400
2x eVGA 7900GS in SLI
Asus M2N32 Deluxe
Now my question is fairly simple.. Is my processor fast enough to push the 7900's in SLI to good rate? I mean I'm not hurting for frames or anything, but in TF2, when I had just one 7900 in there, I was getting about 50~60fps.. Now that I have them in SLI, I'm only getting about 55~65..not a heck of alot more.. So I'm wondering is it that my CPU can't push the game fast enough to pump out more frames, or if the 7900/7900's are just maxed out.
Thinkin' of going w/a black box 5000+ real soon. Thanks for any help you can offer!
TF2 could just be one of those games that don't take advantage of SLI.
What resolution are you playing at?
I think the video card is always the bottleneck except at very low resolutions. Have you tried any other games and compared their FPS?
SLI only gives a noticeable improvement over a single card solution if you're gaming at high resolutions (1600x1200+) and if, as Danny mentioned, the game takes advantage of it. Try what PhantomFelix suggested and test with other games. If you're on a 22" or smaller monitor, don't expect a huge boost from SLI.
Haven't checked the FPS in any other games.. I'm running TF2 at 1680x1050.. I just dl'ed the UT3 demo, so I'll see if I can get the FPS to show there or something.
I'm thinking it may be my CPU bottlenecking, because I did a 10% oc to 2.1ghz, and got 5 or 6 more frames on average, so then I jacked it to 2.3ghz, just to see what would happen, and I was up in the high 70's..
Who knows.. seems like it should be faster though.. oh well. Thanks for all the suggestions guys..!
