This will be used for gaming, surfing, normal computing, benchmarking and bragging. I do not need extra space because I have a 320gb drive for storage. I plan on putting my OS and applications on the array, and all my data on the 320.
I may take the advice and go with a 2 drive array instead if a 4 drive array will actually be slower for what I'm doing.
And please no posts about the dangers of Raid 0. I know the dangers. I will not be storing any data on the Raid 0 array.
Thanks
Ribs
Yes they are as fast, but I'd just use 2 and not 4 in RAID0 unless you needed some real high STR rate. You'll have plenty of STR with 2 and you won't lose much, if any, seek time as compared to 4. Links below to some HD Tach benches of 36, 74 and 150 models:I thinking of getting 4 of these for a 4 drive raid 0 array. Are these as fast as the WD740ADFD? I don't need the extra disk space, just the speed.
Any hard facts, links or charts?
Thanks
36GB ADFD
74GB ADFD
150GB ADFD
150GB AHFD
What's a double sig?Please no double sigs![]()
If you use a single raptor 150, it will use less power than 2 raptors.
Does this have anything to do with my question?
Thanks
ribs
Yes, if you are going to have 4 drives totally 150GB, you might as well go with a single drive. It would use less power and produce less heat than 4, or even 2, drives. RAID0 really only benefits for video editing or photo editing. It really depends on a lot of options, but for at least 90% of the time, RAID0 is not worth it.
This is a double sig below
protias
My name is seen as the poster and now at the bottom of the post. Read rule #25![]()
Thanks for the info. No more double sigs.
As far as the Raid goes, I will probably go with 2x 36gb raptors, unless I find some convincing info that 1 drive will give me the same performance in which case I will probably go with 1x 36 gb.
Thanks
Than
Go with 2x 36's, you probably won't need all 4 drives, but it wouldn't really slow you down. Even is heat/space/power is not an issue, I still think go with 2 drives and use the extra $200 you would have spent and use it for a better case/powersupply/dvd burner/data backup drive/etc
Thanks
Than
