I got a new WD Raptor SATA150 yesterday from newegg. My HD setup prior to this was 2 IDE hard drives. I'm running Win XP SP2. I connected the WD Raptor to the sata power supply and to the mobo's sata port 1 ( mobo is a Abit AN8 Sli). I turn on the system and it begins to boot. I forgot that I had left my partition magic cd in the cd drive and it starts booting from the cd. I just hit the reset button and remove the partition magic cd.
As the computer is rebooting, my monitor says that it can no longer receive a signal. During boot up the HD indicator light blinks a couple of times but remains solid after a few seconds. The computer doesn't boot, and the monitor is in suspended mode with no signal. I disconnected the new stata drive and left my old hard drives connected and was able to boot into windows again.
The sata drive I got was an OEM, it didn't come with cables (or even a jumper pin to designate master/slave). So the sata drive doesn't have any designation on its jumpers. I thought that this would default to 'cable select' but I'm not so sure now.
So after I was able to boot back to windows with the sata drive disconnected, I decided to only have the sata drive connected to the mobo. So I disconnected the power and ide cables of old hard drives. Again I wasn't able to get a signal to my monitor. I tried to revert back to only having my old hard drives connected to the system so that I could do some research on the issue, but now my old drives were giving me the same problem.
I tried reseting cmos, but that didn't help. Does anyone know what I should try next? The new hard drive is not formatted.
The sata drive is the Western Digital Raptor WD1500ADFD. Thanks.
