Gilthanis
[H]ard|DCer of the Year - 2014
- Jan 29, 2006
ChristianVirtual's request in the WCG recognition thread inspired this thread. I didn't really want to discuss it in open forums due to some of the tips not being always looked upon as fair.
Sometimes work units are hard to come by, are set to a lower priority, and are gobbled up as soon as they are sent to the hopper. It helps to have a few tricks up your sleeve. And as always, the more hands on your are the better off you will be of actually getting your fill.
HSTB and BETA work units are highly sought after at the moment. BETA almost always.
I recommend using VM's for this honestly. Set the VM's to use a profile like "home" , "work", or "school". Then set that profile to only pull BETA and HSTB. Make sure to uncheck the box that says send work if selected projects have no work. Be careful with profiles because if you change the "default" profile, it will change the other 3 to match it. Yes it is stupid like that but WCG has not fixed it otherwise.
Second thing I would do is set each VM to use the cc_config file.
<cc_config>
<options>
<ncpus>48</ncpus>
</options>
</cc_config>
48 is just an example for a 48 core machine. Change this number to however many cores you want BOINC to think you have. This means that regardless of how many CPU cores you assign to the VM... BOINC will try and download work based on how many CPU's you make it think you have. You can always change this back to something to match the VM after you get work.
You will want to do that on all the VM's because the more buckets you set out, the more rain you will catch. The clients will continue to back off each time it requests work and fails to the point of 24hours. So, you may need to manually update them every now and again or set up some scripting.
There is a thread at WCG about doing some of this and using task scheduler. https://www.worldcommunitygrid.org/forums/wcg/viewthread_thread,39670
Some people have used cron jobs in Linux to constantly ask for work.
The problem with asking for work too much is that it hammers WCG servers. The above linked thread talks about other user's experiences on times they have been most successful for getting work.
<cc_config>
<options>
<ncpus>48</ncpus>
</options>
</cc_config>
