D
Deleted member 88227
Guest
Are you entering that value in the "Use at most __% CPU TIME?"
i take it that's in the network usage for minimum work buffer and max add work buffer? I would want to change the max add work buffer to 1 or minimum ?Yes increase how many it stores to 1 day and see if you get some to download. I got days worth of Rigid before a bunch of non rigid. It seems to come in waves
Any idea how I move my tasks from an old install over to a new install?
Will they re-download?
The old ones will time out and get sent out to someone else and you'll get new ones.
Aren't we [H]ordes?time to horde
