Riddlinkidstoner
- Aug 12, 2006
Been a long time since I've put together a rig. I'm still running a Core 2 Duo based system I'd like to butcher up to a new one. I do play games but nothing high end, mostly SC2. Just wanted a nice upgrade for better performance all around.
Light gaming like Starcraft 2
$600
Renton, WA
CPU, RAM, Video Card
Antec 300, Kingston HyperX 120GB, WD Green 1TB, Antec Earthwatts 430w
6) Will you be overclocking?
Yes
23" 1920x1080
2-3 weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Nothing specific.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Windows 8 Pro
Current rig is:
E6600 OC'd to 3ghz w/ dying Arctic Cooling Freezer LP 7
4GB G.Skill
Gigabyte EP43-UD3L
Diamond HD6570
$600
Renton, WA
Yes
23" 1920x1080
2-3 weeks
Nothing specific.
Current rig is:
4GB G.Skill
Gigabyte EP43-UD3L
Diamond HD6570
