WaveMaster and Forton PSU
GaleForce
Had a question about fitting a PSU inside of the WaveMaster. The PSU fits inside alright and all, but there is extra room behind it, and no holes on the side or bottom to secure it. That means after I put the bracket back on on the back of the case, I can push the PSU around its little cage. Its secured well enough, but its kinda annoying if im pushing the power cable in or something. Is there anyway to secure it?
Uh, doesn't the PSU have holes to screw it to the bracket itself? That's the whole point of it I thought...
im not exactly sure whats going on inside ur case. maybe some pics?
