yes, however I cannot tell you by how much, I could not find a power vs cpu frequecny curve in the AMD documentaion.
To clarify, under load the cpu will both pull more current from the motherboard/powersupply and dissipate more heat. Same at idle but that is not a concern as it will pull less at 2.5 and idle than it would at full load at 2.3.
When OCing it is important to consider proper cooling of both the cpu and motherboard cpu voltage regulation components to ensure long life and reliability. It is not difficult, just needs to be done. Modest OCing usualy requires only a better heatsink and good case airflow to be very successful.
