OK I want to overclock my PC to I decided to watercool it for better temps. I went and bought the best of gear.
Swiftech MCP 655 pump
Thermochill 120.3 Radiator wit 3 120mm Akasa ultra quiet fans
EK Supreme Universal CPU Waterblock
Swiftech MCW30 Universal Northbridge Waterblock
Thermaltake CL-W0031 AquaBay M3 Reservoir
There was no room in my case so I bought a barebone and installed the pump and res in it and rad on top of it. It sits on a shelve up over my PC and the loop runs from it to my PC waterblocks and back to the barebone. Fans are at full speed and pump also. Im using Primochill PC ICE coolant in the loop. So far my best temps have been 10c lower than my air cooled setup but when the room is hotter I only get about 4 - 6c lower. I need better themps for what I paid for this setup. I do recognise 2 things which may be degrading my setup. 1 is the thermaltake aquabay. The inlet and outlet on this res is only 1/4" ID while the rest of my loop is 3/8" ID. What do you think? Is it slowing down my flow and performance. I think it may and would rather a T loop instead but am unsure about how complicated they are. 2 is the quick connect couplings I have on the loop between the PC and Barebone to seperate the two. Again only 1/4" ID as thay are all I could find online. Are these affecting my loop? Any suggestions please are welcome and thanks.
