officermartinez
- Jan 21, 2006
This is probably a very simple YES or NO question. I am not a noob to watercooling but I am a noob to watercooling my NB and SB chipsets. I own a XFX 680i LT mobo and last week, I removed the stock fans that come on both the NB and SB. I purchased 2 *revised* Swiftech MCP30 chipset waterblocks (with the hard mounts). Now here is my question..
Since I had to unplug with both fans off of the NB and SB, will my system even boot up with those fans unplugged? I KNOW that when I did NOT plug in a CPU fan when I watercooled my processor, the system would NOT boot up. I guess it senses that there is NO fan to cool the processor so in order to prevent damage, the system will NOT power on unless there is fan plugged in. The only work around I found for that is, plug in a spare fan on the CPU fan header, boot into the bios and manually set it to NOT monitor the CPU fan.
Is this also true with the NB and SB fan headers?
PS.. Moderators.. Since this is a question about my motherboard, I didn't know whether to put it here or since it involved watercooling, to post it under the overclocking/cooling section. If it needs to be moved, feel free to migrate it.
