Hello;
I haven't played with watercooling more than using Corsair's H50/H100 and an old Koolance Exos for my Ahtlon XP way back then.
What I'm wondering is: if you're going to put your GPU under watercooling, is it better to buy a reference board?
Usually they're cheaper because they don't have fancy coolers, but I imagine the defaul layout for the PCB is also desired?
