Ordered this today fron jab-tech.
KU4246 Swiftech Apogee GTZ Extreme Performance CPU Waterblock $61.95 1 $61.95
SKU4586 Black Ice GTX 480 Radiator
Options:
Barb: 1/2" High Flow
$129.95 1 $129.95
SKU9933000 Plastic Tubing Clamps - Black
Options:
size: Large Size (G)
$0.40 10 $4.00
SKU3519 1/2"T Line for 1/2" ID Tubing - Clear $0.99 1 $0.99
SKU7894 Sunbeam Rheobus Extreme - Black $32.95 1 $32.95
SKU3865 Arctic Cooling MX-2 Thermal Compound $5.95 1 $5.95
SKU_2867 120mm Black wire fan grill
Options:
Fan screws: Not required
$1.09 5 $5.45
SKU_2385 Budget Black expandable cable sleeve kit $6.99 1 $6.99
SKU1929 12" 3 pin extension cable - FC33-12BKS - Black Factory sleeved $1.09 2 $2.18
SKU5159 18" 3 pin extension cable - FC33-18BKS - Black Factory sleeved $1.19 2 $2.38
SKU1738 Primochill Liquid Utopia - Purple $9.95 1 $9.95
SKU3712 Swiftech MCP655-B 12 VDC Pump Without speed controller $64.95 1 $64.95
SKU_2868 80mm Black wire fan grill $1.19 2 $2.38
SKU7070 Scythe KAZE-JYUNI "SLIP STREAM" 120mm Case Fan - SY1225SL12SH - 1900rpm $7.50 4 $30.00
SKU_2431 ClearFLEX 60 Tubing 1/2" ID / 3/4" OD $0.99 8 $7.92
Subtotal: $367.99
Shipping cost: $11.17
TAX 8.38%: $31.75
Total: $410.91
I'm going to put this on my old Li case with base interest in my up coming i7 upgrade. Got's to do some future proof cooling. ON being the key word here. The old Li is full. So the rad and pump will be external with a basic T-Line. I don't expect more stable higher OC at this point. Just a cooler OC prep'ed for i7.
While some of the components are not the best. I feel there all above average to above.
Stay tuned! The Q6600 goes on water being prep'ed for i7 in a case I can't and wont part with as my main box. Call me a old Li case softie.
psy
Options:
$129.95 1 $129.95
Options:
$0.40 10 $4.00
Options:
$1.09 5 $5.45
Subtotal: $367.99
TAX 8.38%: $31.75
Total: $410.91
psy
