So, I'm planning to go for water cooling for my PC as I wanna reduce the heat generated from it. I just got a few questions that I wanna make clear so I will know what to get and how to do it.
1. Which brands are known for best outcome and is easy to setup? More of plug and play kind of thing. I don't wanna do to much modding of my case to get it to work.
2. Once watercooling is installed and working. Should I turn off all the fans of the PC? Such as the top, front, back and side?
3. Does watercooling need a flush cleaning or new fluid each day?
and last but not lease. How much am I looking at for the heat reduce and sound coming from my PC?
Thanks!
Thanks!
