Jul 24, 2020 #1 L Lucky75 Limp Gawd Joined Jul 22, 2020 Messages 143 Hello guys, I want to know what is perfect configuration on pumps and fans speed for very low noise ?
Jul 24, 2020 #2 VanGoghComplex 2[H]4U Joined Apr 5, 2016 Messages 2,286 D5 pump, static-pressure optimized fans, and as many low FPI rads as you can cram in your case. Use every available slot and consider a larger case if you're not already in one that's good for water-cooling.
