I thought I would share my first water cooling project with you guys. I haven't seen many people cool a sff and keep everything internal so that is what I sought out to do.
I started with the Silverstone SG01. I picked this case because it has a little extra room where the hard drive cage is held. Simply moving the hard drives frees up enough area to fit the water cooling equipment.
I picked the following components to put in the case:
DDC 12V pump
Storm waterblock
maze 4 low profile gpu waterblock
DD 80mm radiator
The tubing, fittings and clamps were all purchased from local hardware stores.
Here is the system being used:
AMD X2 3800+
BFG 7800GT
Corsair XMS 2x 1gig PC3200
ASUS A8N-VM CSM
WD 74gig Raptor
Seagate 300 gig
Haupaugge 150 MCE
The entire reason I went with dual core is because I run Win MCE and have the Xbox MC extender. That way I can keep gaming while the system sends an episode of Lost to the TV to keep the wife happy.
DDC 12V pump
Storm waterblock
DD 80mm radiator
AMD X2 3800+
BFG 7800GT
ASUS A8N-VM CSM
WD 74gig Raptor
Seagate 300 gig
Haupaugge 150 MCE
